Google maps navigation viewed at angle
ScarySulley
11
When using Google Maps Navigation, how do you get it so as you're following the directions the maps is viewed at and angle so you can see further ahead on the map. Also how do you have the screen/map turn as the car turns?
Right now it's just looking down and with no angle/tilt on the arrow and the orientation stays "north up" all the time. It used to do this.
I'm still new to Android, so maybe I missed a setting or something.:confused:
I might have misread what you asked, but I believe if you don't want the map to always show north tap the compass in the top left of the screen.
Sent from my ADR6400L using Xparent Blue Tapatalk 2
I'll try out that north thing as soon as my phone gets a GPS signal. The signal is so flaky.
Any ideas as to what I could be doing wrong for the angled view when navigating?
Thanks for the replied btw.
EDIT: Ok GPS signal came in. Tapping the compass resolved both issues. Thanks!
