instead of using KDZ, i used lg R&D tools (or something like that) and there was an option to merge a model.dll file and a DZ file together, and then flash it.. i did that didnt know that they were mis matched and didnt belong together untill AFTER the test was done, it gave me this:
[R&D Test Tools Log File]
21:14:17 : Launching SW update
21:14:17 : Unpacking KDZ
21:15:51 : KDZ file extraced
21:16:11 : Files were extracted.
21:16:11 : LGMobileDL Load.
21:16:11 : Port = -1
21:16:11 : Connecting to phone
21:16:21 : Check Phone mode = 1
21:16:38 : Phone type check.......
21:16:43 : LGMobileDL.DLL Loading....
21:16:43 : _SetAuthMark Fail
21:16:43 : AuthMark?? ??Ȯ?? Phone?? Write ???? ?ʾҽ??ϴ?!
21:16:43 : LoadCDMAPhoneData() Error
21:16:43 : _DetachDLL Call
21:16:43 : _DetachDLL Call End
21:16:43 : Param : Path = C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone\LGP509-V10s-APR-23-2011-TMO-US-DZ.dz
21:16:43 : Param : moduleDir =
21:16:43 : Param : waitTime = 33000
21:16:43 : Param : UsbHighSpeed = 0
21:16:43 : Param : PhoneMode = 1
21:16:43 : Param : BinVersion = V10S_00
21:16:43 : Param : AuthMark = 0
21:16:43 : Call fn_StartUpgrade
21:17:27 : Smart : wParam = 100, lParam = 1002
21:17:27 : Step : Upgrade Error error code = 1002
21:17:27 : ResetStartInfo() Call
21:17:27 : _DetachDLL Call
21:17:27 : _DetachDLL Call End
21:17:27 : FreeLibrary Call
21:17:27 : FreeLibrary Call End
21:17:27 : ResetStartInfo() Call End
21:17:29 : ===FINISHED===
21:17:39 : OnModelDllMsg(OnMsgFromModelDll3GQCT_PDA) delete m_pLGCyonUpdate
After this frightening log my phone shutdown and has been IMPOSSIBLE to boot on since then. its been a week and ive tried about 40 or 50 different methods to fix it and/or boot it on. after research JTAG is the only thing that can fix it.
