O.k.. Thank you for the advice. I uninstalled my virus progam ran z4root and got a lot further. It jusf went back to my apps screen. Does that mean my phone has been rooted? How can I be sure?
Sent from my SGH-T499 using Android Central Forums
I have never worked with this device but I figured from what you were describing that anti virus apps on your computer were involved.
Have you tried running the super one click again? Don't worry about what I said with the virus stuff, they aren't viruses it's just that is what your virus apps sees these rooting applications as so it protects itself.
To tell if your rooted goto the Google play store and download titanium backup. Install it and run it... it should prompt you shortly after starting for root access. Otherwise if you aren't rooted it will give you a message about your device not having root.
