Permissions Denied seems like a neat app to tweak permissions of apps, but it takes a while to load (i.e. it reads app permissions on run, and this could take a while). So when you just need to check some app's permissions (hopefully also those that you disabled by means of Permissions Denied), is there any quick way to do it (other than opening play.google.com in your browser and checking the app's homepage...)?
