How do I change the text notification sound to be recurring? As in it'll keep going every 30s (or however frequent) until I check it? This is on an Incredible (although knowing how on an X would be nice also)
Also, is there a way to set the ringtone for an entire contacts group? I found the setting for individuals, but not for the whole group.
Oh and the "check these threads before you start a new one" is AWESOME... unfortunately none of the suggestions held a solution
