Hello
I have the S4 with the Spigen Neo Hybrid case, sample picture below.
spigen neo hybrid - Google Search
My original charger that came with the S4 fits perfectly into the phone with the case. I purchased following from the Verizon Store but the car charger will not work unless i take out my case.
Set Your Location
Does anyone know of any car charger that will fit the Spigen Neo Hybrid case that has a dual port charging?
Set Your Location
