I am unable to change the brightness on my 2.2 Evo. Earlier this week I had to get a warranty replacement for my original phone, and this is on my new phone. I'm uncertain if it worked right off the bat, as this is the first time I've tried to adjust the brightness since receiving the phone, but I never had a problem before. I wanted to see if anybody had any suggestions before I tried wiping the phone.
I hadn't downloaded any apps/widgets that should of affected the brightness settings at all. I always just went through the display section of the settings. I can turn auto-brightness on and off and slide the slider all I want, but nothing changes. I'm not sure at what percent the brightness is stuck at, but it seems pretty bright. I tried downloading some 3rd party brightness apps/widgets, but they're unable to change anything either.
Any help is appreciated.
