Android 4.2.2 issue with strange feature How to disable?
v_enus
3
Hi, my first post her so be gentle :)
i've looked all over for a solution but its a little difficult without knowing the name of the feature.
The problem is, the new phone i have purchased is a 4.2.2 android device and when blowing at the phone (microphone) it registers it as a back command
now somehow it keeps doing it even if i don't want it to, just a little wind does it.
I NEED to disable it somehow... :'(
its driving me insane :confused:
hope somone can help, thanks for reading.
Robert
Welcome to Android Central! That's interesting. What kind of phone is it?
I'll be honest with you, considering it's a no-name device, it's more likely a bug than a feature. Go through all of the Settings one by one to see if there's anything that might remotely cause it. Check the Accessibility settings. Also look at every preinstalled app.
Have you tried a factory data reset?
ok, and yes i have done it a few times.
I have a feeling it might be the touch buttons that are too sensitive and get activated by air.... lol
thanks for the tip though.
I just thought it might be a hidden feature... :P
vuniverse
