How do I ungroup Twitter tweets?
gemery#CB
Banned
Jul 26, 2013
65
Twitter- Grouped Notifications
In a recent upgrade to the Android Twitter app, notifications changed from individual notifications of those that you follow to one group of notifications for all new tweets.
Problem is, there is not way (that I know of) to select from the "grouped" list of tweets to see the one that you wanted.
Prior to this upgrade, each tweet was a separate new notification, so you had a list to choose from and you could look at them much easier..
Is there a way to change to ungrouped notifications for this APP, or a seperate program that will do this?
I have been searching and searching and have not figured out a way yet..
version 5.28.0 of the Twitter application, this is on a DROID MAXX running 4.4.4 (I am assuming that all users of 4.4.4 have this...)
Gil
gemery#CB
Banned
Jul 26, 2013
65
Re: Twitter- Grouped Notifications
would you believe, I just went and cleared the cache of the app, and now they are separated...
Couldnt be that easy..
dbphx
If only it really was that easy. Didn't work on my S4 with 4.4.2.
Another other suggestions?
glda19
