I just got my Galaxy S5, and the volume gets louder when I pick up my phone to answer a call or if I wave my hand over the screen, even though I have the motion option set to pause/mute when the screen is covered. Is there anyway to stop this? Ideally, the volume would get lower when I pick up the phone.
Update: It turns out it's not just when I pick it up. Even if I leave it on my desk when it rings, the first ring is normal, the second ring is super loud, the the third ring is muted, and then it goes through the cycle again.
