How do I send a string from my Windows server to my Android device using wifi via socket connection?
Saravanakumar_shlok
How to send a string from my windows server to my android device using wifi via socket connection.
Hai there, I am trying to send data to my android device from my windows m/c , but i am not able get the solution.Message from Android to Windows machine is working but windows to android not working. I am trying for last 2 days but still its not working for me. I have searched many sample server/client applications from internet but its not working. Pls help me on how to to send data over the sockets.
Thanks in advance..
Re: How to send a string from my windows server to my android device using wifi via socket connectio
Do you have the Android app listening on the port?
Yes , i have mentioned the Server Port for Server side and i am listening to the same port Client side.
Qtinopu
