Issues restoring original rom backup from clockwork..
zuninet
Before I played around with the CM 12 nightly I took 2 backups of the stock rom, one from online nandroid and one from clockwork. I tried to restore on of them from clockwork today and the restore goes fine but when the stock room boots everything crashes.. i.e every app. Any ideas?
Note that my backups are on my external sd card.
Are you doing a factory reset from within CWM (ClockworkMod) before performing the restore? This shouldn't be necessary but it might be worth a try.
kankuraon
