Why am I unable to select additional Chinese characters when Magnification Gestures is turned on?
A
AC Question
Hi,
i noticed that when the Magnification Gestures feature is turned on under Settings --> Accessibility --> Vision, the number of Chinese Characters becomes limited and user is unable to tap on the ">" to choose more characters.
This appears to be a software bug as user also need to view some other text/images with magnification feature. It should not be made mutually exclusive.
This bug was noticed at least in both Kit Kat and Lollipop version of Android.
Anyone facing the same issue?
Thanks.
