Installing Stock Rom, Image is too large using mfastboot. How can I fix it?
  • Start date Start date
A
AC Question
Trying to install Stock rom firmware on my Moto G 2015 XT1072 phone. Using official stock rom with Minimal ADB and Fastboot but using mFastboot. Still I'm getting the message; image is too large. I noticed I get an error of; Max sperse size 256mb and the actually system.img sperse file is bigger than 256mb. Could that be the problem, if so how do I fix? Thank you
Re: Installing Stock Rom, Image is too large using mfastboot
Welcome to Android Central!
Make sure that the image is not corrupted and that you have the correct image.
ryzengames
