Why is my mobile data and wifi getting automatically switched on every time I unlock my phone?
A
AC Question
i use lenovo a316i model, my phone's mobile data and wifi gets automatically turned on whenver i unlock the device.i've tries factory reset but the problem still prevails.help me out. thanks
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,602
4,751
113
Re: mobile data and wifi getting automatically switced on everytime i unlock my phone
Welcome to Android Central! I assume you are manually turning off wi-fi and mobile data before locking, correct? Go to Settings>Wi-fi, tap Menu>Advanced, and make sure Scanning Always Available is turned off. But this wouldn't explain why mobile data is turning back on--how are you turning mobile data off, from the Settings>Data Usage​ menu? Or do you have a toggle widget?
Faiyaz Mohammed
yeah im switching wifi off manually, but again when im about to unlock or the lights blinks it getting back on again....i don't use mobile data at all
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,602
4,751
113
See if it still happens in Safe Mode. If it stops, then it might be a 3rd party app that's responsible. On most Android devices, while powered on, press and hold Power until the Power Off menu appears. Press and hold the Power Off selection until the Safe Mode prompt appears. Tap OK.
Satish sri
Hi
I am happy to share this solution. Its because of the third party unknown app. Its get installed automatically while we browsing the net and then it asks the admin access permission. It won't leave you until you accept it. So just find out that app and uninstall. For your info please check in the settings->security->device administrators and find that harmfull app, uncheck it. Finally uninstall. Works 100 percent.
Hope it will help you.
Thank you.
smokedog87
