Need Help! The contacts storage of my phone is really screwed up. What should I do?
John256145
5
Need Help! The Contacts Storage Of My Phone Is Really Screwed
Ok, so my phone's contact storage is really screwed up. When I go to my Contacts, I see a screen saying "Contact list is being updated." and nothing else. If I go to Phone, and I start dialing in a number, the contacts with that number I dialed appears, but if I try to open a contact, I get a message saying "No application found to view this contact." Luckily, I did have a backup of my contacts, but if I try restoring the app and data, the restore process is stuck on the "Restoring App" screen. (I'm using Titanium Backup.) I also notice that on the list of my backups, "Contact Storage 5.0.2-14" has a line across the name, possibly meaning that the app is not on my phone. Does anyone have any suggestions on what I should do? I want to at least try some ways that it could be fixed without factory resetting, because that feels like a last resort. But I may need to if I can't seem to find a solution. Thanks in advance.
Re: Need Help! The Contacts Storage Of My Phone Is Really Screwed
Hello, welcome to the forums! Have you already check if those two apps are included in your settings - apps - "all" tab? (Contacts and Contacts storage). If they are not there check in the "disabled" tab. Which device do you have? Are you using a third party contacts app or just the stock one?
(Hey there, sorry for extremely late reply.)
So I checked my Apps and I did find contacts, but I couldn't find Contacts storage anywhere, I even checked the "disabled" tab. My device is the Moto G 2nd Gen and I'm using the stock app.
I finally figured out a way to solve this. I simply flashed a stock rom to my phone.
Jeferson de Jesús
