Why isn't the SD card in my Galaxy S4(4.2) writing?
Kawooa
Galaxy s4(4.2) sd card no writing! Need help!
My galaxy s4 is on android 4.2.x. I have never updated it. Due too rooting. Now I cannot edit anything on my sd card. I cannot delete. Now moving images to another folder. This is causing many problems. Rebooting and removing the card has no effect. A reboot will cause anything deleted to come back. This is so annoying. I will copy everything off my sd card and format it in windows soon. I will also pull anything I need from the phone and reset it. I need a fix and fast!
madra29
