Why won't my EM756 charge?
A
AC Question
EM756 Won't charge
Plugged it in, but will not turn on even after 1 hour and still plugged in?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,606
4,756
113
Re: EM756 Won't charge
Welcome to Android Central! How old is the tablet? Leave it plugged into a wall outlet for at least 4-6 hours, undisturbed, then try powering on again. Press and hold the Power button for at least 20 seconds. If it doesn't work, then the battery may have failed, or perhaps the motherboard. Off-brand tablets like your Emerson are much more likely to have hardware or firmware defects, so this would not be surprising.
MrsDCS
Except Emerson isn't an "off" brand.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,606
4,756
113
I'm afraid it is. From what I can tell, Emerson's devices are manufactured by Funai, a Japanese company that is not known for making high quality tech devices. It's similar to Polaroid or RCA. Just because a device has a historically recognizable brand name doesn't mean it's high quality. They're often cheap Chinese devices that have the brand name slapped on.
