A
AC Question
Android Setting wont open its says launcher 3 stopped working after Factory reset
I think Android assistant app accidentally deleted important file then i cant find android setting so i tried factory setting but after that i still cant find android setting on home when i tried clicking the one on slides it just says launcher 3 has stop working now i cant set up my wifi or use anything HELP
