S20 Ultra opening random web browsers to spam pages
Honestly the simplest way to get rid of, and avoid, these kinds of issues is to avoid installing any apps you don't %100 have to have on your device. I know for a lot of folks installing apps on their phone is half the fun, but scammers know this and target apps. There is always a good amount of sketchy apps on the Play Store because sketchy developers are putting them on as fast as Google can remove them... and yes, they have multiple ways to get around Google's security.
You have to weigh the fun of installing apps vs the need and risk. It's the same thing with visiting web sites and clicking on links.
I don't really have a tonne of apps.
The apps that i use are pretty major apps from I'd say big companies.
I kinda just use the ones i always use but i did go through and delete all the apps that had updated within a short time of the problem starting.
I downloaded Nice Catch and it really hasn't given me any information on either the toast services, Detect Commercials, or Screen Wake up History.
Too bad I was hopeful to find a culprit here!
Maybe clear data in both browser then force stop it will reset them
Of course, no problem. Also another suggestion. Download the app virus total from the play store. It might help you pinpoint the app. Most likely will have some false negatives as well so don't freak out lol
Mr Bojangles1, I downloaded the app and reviewed the list. There were a few that read with a '?' but when i looked at them it seems it may not have like the permissions. I deleted a few that i really don't use but not sure i found the smoking gun in here.
Keep firing any suggestions, I'm trying to get to them all.
Man this is annoying
Welcome to the forums. You could try a couple of things next time you get the same issue. In the meantime enable the Developer Options tapping 7-10 times the Build number in Settings - About phone - Software information.
- As soon as you get that spam page take a screenshot and posted here without any edit.
- Go to Settings - Developer Options and take screenshots of Memory and Running Services screens.
There's a big chance we can get more information from those screenshots.
This is one of the sites:
These are the screenshots right after a browser opened.
Which apps show up after Google Play Services in your screenshots? Have you already tried clearing storage for Chrome?
Yep. Tried that last night as well.
Even rested chrome.
I'm sure it an app because it opens up both my chrome browser and the Samsung that's installed.
I don't remember if you tried safe mode if still happening?
What are you usually doing when this happens? Does it happen on data and wifi ?
Another question, have you checked your play protect settings to make sure it is on and scans apps
If nothing works still then you might have to reboot into safe mode again. And remove every app you have downloaded 1 by 1. But after each one you remove reboot back into normal mode and see if it still happens. Keep doing that until it doesn't do it lol. Make a list of the apps if you want to add them back.
It sounds like you've been pretty careful overall... unfortunately sometimes this can happen regardless of how picky you are about your apps :-\ You may have to start cleaning out your installed apps like Mr. Bojangles suggested until you find the one giving you the problems.
Try resetting your ad identifier in Google settings. Then open both browsers go to settings->site data->clear all. Then go to notifications in site settings and clear anything there as well. Make sure blocks ads, popups, and redirects is enabled. Also if you are logged into a computer with the same account and are using sync then do the same thing on your computer browser as well.
bukablokiratmpaninmobile
