How do I connect my Android device when it is locked due to incorrect pattern inputs?
  • Start date Start date
A
AC Question
how to connect my android device when it is locked due to incorrect pattern inputs?
i need to connect my device to a wifi connection but i cant..
Re: how to connect my android device when it is locked due to incorrect pattern inputs?
Contact the device manufacturer or carrier and see if they can assist. If you don't know the correct password and it's timed out then you likely can't access it again without resetting it, which they can help with.
kagutamuseven
