Can I change my GZone commando wifi to accept 7 digit codes on wap?
A
AC Question
can i change my gzone commando wifi to accept 7 digit codes on wap
I need to access wifi at my job but it will not let me connect using 7 digit password for access. When the password was put in the connect box is grayed out.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,602
4,751
113
Re: can i change my gzone commando wifi to accept 7 digit codes on wap
Welcome to Android Central! Does it seem to want 8 digits instead? If you add an extra 8th digit, does the Connect button become active again?
