So my S4 has suddenly stopped sending texts with the SD card in. It receives texts, but even that isn't as facilitated as it should be considering I receive two of the same messages later than I should. When I attempt to send a message, it doesn't say the message was not sent, or unable to send message, but rather it just keeps trying to send to no avail. But when I remove the SD card, the messages trying to send, send, and any new texts after that send smoothly.
I tried restarting my phone, of course, removing and then reinstalling the SIM card, running malware bytes and avg (no issues), uninstalled several third party apps, and cleared my system's cache. None of this helped. The only thing that did was removing the SD card, which I forgot to mention I have only had for a month and has 10GB remaining out of the 16. The only thing I did not do that I thought of was a factory reset, but considering it seems to be the SD card, I don't see how that would help anyway.
If there is another post like this somewhere else, I apologize, but I did not find it. I would greatly appreciate it if someone could share a fix, because this is a pain in my *** lol.
