A
AC Question
need help with phone i6 plus lcd driver
Hi there.
So i bought one of those cheap chinese iphone 6 clones not knowing exactly what model.
After bricking the phone with wrong software i cant get it back to work.
After trying many rom's i found one that helps me a bit. ===>> IPhone 6s Plus e165_jb3.72emmc
The only problem i have is my screen shows white lines blinking from left to right and i cant find any other to work.
If someone could help me out that would be amazing.
Here is some info i was able to find after opening the phone.
phone model: mt6572 512mb ram 8gb rom 5.5 inch 540x960.
Sticker on the inside says: e165_jb3.factory_ATA.72jb3.emmc.xg.s.160...BOM_V2. 0_20160114
Any help here would be much appreciated.
Hi there.
