Re: What does the letter N shape mean on the tool bar
Welcome to ACentral: NFC=Stands for "Near Field Communication"
Is a set of short-range wireless technologies require a distance
of 4cm to initiate a connection. NFC-Allow to share small
payLoads of data between an NFC tag & an android
powered device or between two android devices
The NFC-icon on the Notification bar it can be turned off
if Not in use: Goto settings locate NFC and Payment
Tap on it and turn off the Switcher on My SGs7- but
can differ in other Phone brands. Hope this help
