A
AC Question
How can I check if the 'Region Lock' is removed from my Samsung phone
I am currently in Malaysia on a business trip, for 3 months.
I bought Samsung J5 2016 model from here (Malaysia), and started using it.
One of my friends told me about this Region Lock that is imposed by Samsung (I used HTC and hence didn't know about this locking). He said that if the phone is activated with local SIM card and if I made calls for 7+ minutes, then the lock should be removed.
My question is: How can one confirm that the region lock is indeed removed? I don't want to go back to my home country, put a local SIM and check.
While I am in Malaysia, I'd like to check and be assured that it has been unlocked. Samsung Service Centre repeated the same thing over and over again : "You need to make 7+ minute phone call and it will be removed. Don't worry." But when I asked how can you guarantee? Show me the proof - there was no answer from them.
Is there a way to find out if the lock is removed? [I know that we can press keys like *#0011# to go to System Menu. Any commands to cross check this lock status?]
Thank you!
Thank you!
