Transparent weather widget no longer display daily weather forcasts. Now I only get hourly reports
Tuxusa
3
Transparent weather widget no longer display daily weather forecasts. Now I only get hourly reports. I have uninstalled the app and reinstalled. I had daily for 24 hours but it changed back to hourly. I would like to see the next 5 days forecast on my home screen.
Tuxusa
3
Never mind I found a support page and fixed it. There is an invisible button or hot spot on the bottom right of the widget. I can tap this invisible button to switch from hourly to daily and back.
MACHAPP Software Ltd
Thank you for your time.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,602
4,748
113
Glad you figured it out! I've used that app as well--it's a good weather app. It's one of the few that actually has a 5 day forecast widget, without anything else cluttering it up.
GuccizBud
53
( two years later )
For some reason the weather hasn't updated in about a week under Foreca as the provider. The other 3 providers that Transparent Weather Widget offers as standard choices ( Met.no, Weather Underground, and Open Weather Map ) are fine, but Foreca seems to have stalled.
