My phone is Lenovo android phone a1000. I turned it off, removed the battery and got the SD card. I used my SD card via card reader and placed some files, then when I put it back and the battery, I power on the phone and now it restarts, shows the Lenovo logo, pitch black then restarts again and it just happens repeatedly. I read somewhere that it needs to clear cache or something that I can't do because I can't get past the Lenovo logo. Thank you for any help.
