Someone had already sort of solved my problem for this but I became curious and began doing trial and errors to try and figure this one out and I'm kind of hitting a dead end here and was hoping somebody here would know.
Basically when I installed a new ROM, the Model Number in Phone Identity said HTC Inspire 4G. When I did a restore with system+data etc etc on Ti, the Model Number went back to HTC Desire HD from the previous ROM.
The solution from the user who ran into the same problem suggested to just do a factory data reset. It does work, I mean sure enough, it brought back the HTC Inspire 4G under the Model number, however I ended up becoming all ocd as to what I restored to have made the Model Number change back to the previous info...so much that I restored a backup with the newly installed ROM with the HTC Desire HD Model Number to try and figure what data/cache restored that information
I know it's probably useless information as I should just stick with the mentioned solution and move on...but...but...I just can't rest until I find out
If anyone knows the information I'm looking for to help a gal out...that would be awesome
