Wont allow me to download certain apps: "Device not compatible", after reset...CLICK HERE HELP!!
Hi there,
I have a LG Optimus 4XD, Its running on Android 4.03.
Before Tinder and LinkedIN worked well on my phone. I recently reset the phone.
Now Tinder and LinkedIN does not work, neither do some other apps.
It says "you have the latest software update"
What is a good solution? Ideally I would prefer running apps that are older and do not use as much RAM.
My phone is not rooted.
Thanks to those that reply.
Hi there,
