A
Android Central Question
Okay, Basically I was wondering what it would take it build your own smartphone. I'm trying to do it for a school project and hoped it would be fun. After doing some research I found out that soldering lots of components is not fun so I decided to buy a used phone and salvage parts from that. I understand that some connectors are different and that might be annoying but can I just add the right connector on the end and solder the ends together. This sounds really dumb and it is. "Really dumb" so if it's not possible could you suggest any ideas.
Thanks.
Thanks.
