Using Note to Self - and sending the note to gmail
Frank Schmidt
Folks,
I am on Pixel 3a ( came from Nexus 5x) and Android 9.0. I use ' Note to Self' while driving. the Note then is then sent to me in gmail. This worked without fail on Android 8. Now it's hit 'n miss ( mostly miss).
I cannot find any switch that allows me to consistently get this to send to gmail.
Evert once and while it will ask which app it what's me to use for the voice note. I pick gmail , but that will work 1X time and that is it.
Any clue on how to get this to be consistent with Google Assistant & Gmail?
thanks!!
The June update had some fixes to Google Assistant - see if it works bettter after the update.
kolorado
