(Tried to find an answer here/on google, but only found solutions for problems with switching from wifi to mobile data..)
My problem is that, since a few hours ago, whenever I switch on my 3G/HSPA+, i lose data connection. Though edge does work, but whenever I untick the "only use 2G networks" box, I lose connection, so no 3G but also no EDGE, what I think is very strange.
If it'd be a problem with my provider, no coverage, then I'd still be getting EDGE when i put on my 3G, right?
Is this a known problem? Is there a solution for it? What would you suggest that I do?
Already switched phone on and off for a few times, re-entered my APN details.
I'd be so sad if my phone just lost 3G/HSPA+ access..
Thanks, Ezra
(btw it used to work, the 3G, have used it before. I didn't change any settings when i lost "it")
Thanks, Ezra
