Problem: Nexus 5 battery drain fast.
Hi All, I have a Nexus 5 Marshmallow w latest updates. A few months ago the battery started to drain fast. I checked which apps may be using a lot of battery but it seems that no app was causing a problem. I replaced the battery with an LG OEM battery and the new battery is now also draining fast. I always keep the wifi and bluetooth turned off when they're not needed. And I have no data plan on the phone; only voice and text messages. Also I keep the screen brightness turned down.
Any ideas on how to diagnose and/or fix fast battery drain on fully up to date Nexus 5? Thanks,
