I was wondering if there is any widgets that cause more battery drain than usual. I have the youtube widget and facebook widget on one of my homescreens. I was told that my battery drain is higher than usual and I was just wondering.
My battery drain source says that cell standby and phone idle causes the most battery drain. Then, sometimes apps will say that there is more usage than what I know has been used. Like for example, it'll say that I used maps for 50% when it says usage time is only like 4 mins. Sometimes it'll do this for other things also like camera.
My usual awake time is like 3 1/2 hours by the time I reach 50% and i would say that the time uaage is fairly accurate. But it just seems like my sleep time is low, and other people have been reporting that they can get like a day and a half of battery life.
