There's literally 134 page thread on xda and not a peep on here. Here's the link to that thread:
https://forum.xda-developers.com/ma...-pro-greenish-display-screen-t3859268/page134
Has anyone checked their device yet? There's a app on the play store called Hw device info that you can use to see which screen supplier your phone has. Many of them that do show the green bleeding get much worse over time. This is a bigger issue for us in the US that import it because there is no way to get warranty support.
Here is a link to the app you can use to check your screen:
https://play.google.com/store/apps/details?id=com.mate20pro
It's a gray background. Slide the brightness down to close to zero in a very dark room and if yours is affected you will see the green like on mine. Hope this helps. Thanks.
