Hey guys today got stable Android 10 update on my Mate 20 pro...any of u ? build number 10.0.0.154
Security patch is 6th oct 2019
Here
Here is the screen shot Huawei is faster than Samsung to stable build of Android 10
on EMUI 10 beta I had some weird issues with wifi and cellular used simultaneously every few seconds causing timeouts while browsing files over my local network. But factory resetting and disabling Adguard apps DNS filtering fixed my issue.Let me know if you're having wifi connection issue like me when updated to Android 10
Where are you located and what Mate 20 pro version do you have?
Tried it for again for while week this time around, back to 9.1 and this time it's for good.
I was on official also 10.0.0.180 doesn't do anything for me. In fact some of my apps don't work anymore.I already have official stable Android 10 on my mate 20 pro...working great
Use hisuite on PC. Select backup or restore ( sorry forgot which one ) then you'll have an option to check older version which will roll you back.How to downgrade back to 9.1
Accubattery pro and GSAM were the most evident that come to mind.Which apps.....
Yup. That was one of the first things I noticed on a different phone. Android 10 rendered those apps useless and I hope they manage to get them working again in the near future.Accubattery pro and GSAM were the most evident that come to mind.
Sad as it sounds, I just cannot live without those two apps.Yup. That was one of the first things I noticed on a different phone. Android 10 rendered those apps useless and I hope they manage to get them working again in the near future.
Oh, don't worry, you'll get used to that.Sad as it sounds, I just cannot live without those two apps.
Yes, more stats are enabled or should I say were enabled Emui 10. Rolled back to 9.1 a few days back.all good.Oh, don't worry, you'll get used to that.
I've seen some people that have no problem with Gsam after Android 10. All of them have the 'more stats' options enabled through root or adb commands, though.
Mmmm, did you tried selecting Don't optimise for Gsam? I'm going to leave it that way for a day and see what happens. Not sure why I didn't try it beforeYes, more stats are enabled or should I say were enabled Emui 10. Rolled back to 9.1 a few days back.all good.
