Widget /time weather and battery level
Terrysteiner
to anyone here,
I have this widget on my phone and love it. for awhile it would notify inside the time circle of missed calls, texts or vms and it automatically stopped how do i set that up again?
Help and advice is appreciated and thank you in advance
Terry
meyerweb#CB
Banned
Sep 4, 2009
6,668
5
If there's a settings icon (usually a little gear) on the widget, tap that. With many widgets, I think the only way to change any options is to remove it from the screen, and then re-add it.
gone down south
2,040
What widget exactly are you talking about ?
On what phone on what OS on what carrier? Stock or rooted? What did you last do before you noticed the change? Etc etc etc
Terrysteiner
Thank you for the responses and apologize for not being more specific. Not sure of the widget name it is the one with the 3 circles - 1 for time/ 1 for weather/ 1 for battery level. My phone is the Droid Razr M. version 4.1.1
Also, with the last software update I lost my NFC is there anyway to get that back?
Terry
japetty
396
to anyone here,
Terry
Try searching the google play store for One More Clock Widget by XXFFRON Software?
AmeliaRodriguez
