After update to 4.3 s4 i9500 dropping wifi connection many times !!
Facing similar issue.
After updating to 4.3 on Samsung Galaxy S4 I9500.
Wifi works for a a few minutes. Then stops working "Your internet connection is unstable"
Auto switch setting is unchecked.
There are issues with the new 4.3 update and WiFi for some reason.
My GS4 doesn't automatically reconnect to known WiFi networks.
I have to either turn off and on the WiFi or the airplane mode!
Not a big deal but it gets a little annoying sometimes. :banghead:
Sent From Inside The TARDIS in a Galaxy S4 Away!
Hopefully Samsung and Sprint get a quick update to us that will fix this problem!
This is happening on T-Mobile devices as well. Anyone heard of a fix yet?
My S4 literally tells me that familiar WiFi connections are to busy or weak and I'm the only person on it.
Wow! That sucks! Hopefully we get an update pretty soon.
I have Sprint and got an update this morning. I hope it fixes my problems reconnecting to known WiFi networks.
owo Emmanuel
