07-21-2022 01:59 AM
26 12
tools
  1. BruceWeber's Avatar
    I have Home and Work set up in Google Maps, but the option to enable them in Smart Lock is grayed out. I can enter them as custom places, which works fine. I'm just wondering why they I can't enable them as Home and Work. Thoughts?
    11-25-2014 01:27 PM
  2. gone down south's Avatar
    Same thing here...
    11-25-2014 01:51 PM
  3. vividrich's Avatar
    Odd. I can enable them, but the feature doesn't work really well for me. It's routinely requiring me to log in anyway.
    Posted from my Nexus 5 via Android Central App
    11-25-2014 02:20 PM
  4. daihard2008's Avatar
    I am using Home and Work as my two trusted places. It works well in both places for me. FWIW, I use a pattern to unlock the phone.
    Standroid43 likes this.
    11-25-2014 02:51 PM
  5. Paddy Landau's Avatar
    Yes, I have the same problem; it's greyed out.
    11-26-2014 04:03 AM
  6. digitalangel's Avatar
    I'm in UK and my Nexus 5 doesn't even have a an option for places.
    11-26-2014 06:20 AM
  7. Paddy Landau's Avatar
    It's being rolled out worldwide (I'm also in the UK). The order of receipt appears to be random. It'll be with you soon.
    It's a silent update, so you have to check every now and then; I don't know if you have to restart your phone.
    11-26-2014 08:14 AM
  8. Paddy Landau's Avatar
    I have just been in a discussion with Google Support for this issue.
    Here is the response, summarised because I was with them for a long time!
    Method 1
    1. Go to Settings > Security > Clear credentials.
    2. Try again to set Home or Work as a Trusted Place.
    3. If that doesn't work (it didn't with me, because Clear credentials was greyed out), restart into Safe Mode and repeat. (To get into Safe Mode, hold down the power button until you see the "Power Off"; then press down on "Power Off" until you see the prompt to restart into Safe Mode; press OK. Get out of Safe Mode by restarting normally.)
    4. If that doesn't work (it didn't with me, because Clear credentials was greyed out), go on to Method 2.
    Method 2
    1. Report the issue to Google Maps (yes, really), as follows.
      • Go to the Google Maps Help Centre.
      • Select Fix an issue > Report a problem.
      • Follow the instructions under Report a problem with the map.
    I have not tried Method 2, because I don't have time right now. If you do, please let us know the response.
    Method 3
    1. Settings > Backup & reset > Factory data reset. Warning: This will do a Factory Restore and you will lose ALL of your data stored on the phone. Ensure that you have a complete backup of everything before you proceed. (Data on the cloud will still be OK.) If you use Authenticator, VIP access or any other two-factor protocol, you'll need to ensure that you can log in to your various accounts without the authenticator apps before you do your factory restore.
    I haven't tried Method 3, because I don't have time. Maybe over the weekend.
    11-26-2014 09:23 AM
  9. parkerhugh's Avatar
    I had same problem as described here, my Home and Work Locations were both greyed out and not available to select.
    But my home and work locations are the same. So I went to Google Maps > Settings > Edit home or work
    I removed my home address from Work and screen then said "Enter work address".
    I went back to Settings > Security > Smart Lock and my Home address was now available to select as trusted place.
    I think the reason both were greyed out and not previously available was because they were the same address and you couldn't enable one without the other.
    Hope this helps someone else.
    Paddy Landau likes this.
    12-14-2014 07:09 AM
  10. Paddy Landau's Avatar
    But my home and work locations are the sameā€¦
    So were mine.
    They were the same because, when I left the Work address empty, Android kept filling it in with random addresses (addresses that I'd never even visited!).
    However, I've copied what you have done and now it works. Thank you.
    I subsequently returned to Google Maps and re-entered my Work address (the same as my Home address), and restarted my phone. It still works (although Smart Lock thinks that my Work address is still empty).
    I have reported this bug; any reader who is affected by this should log in there and click the star.
    EDIT: See next post
    12-14-2014 10:39 AM
  11. Paddy Landau's Avatar
    It turns out that I posted the bug in the wrong place.
    I have re-posted it in the Google Product Forums.
    12-15-2014 06:32 AM
  12. Tom Matheney's Avatar
    For me the steps above (deleting home/work then adding them back) worked, thanks. Perhaps something to do with enabling smart lock after entering home/work addresses, as I did when I first set up my phone.
    12-25-2014 02:43 PM
  13. jefferai's Avatar
    I have a slightly different but maybe related problem: Trusted Places doesn't show up at all. I have Play Services 6.5.99 so that shouldn't be an issue. I've tried removing Home/Work and re-adding just one of them...no dice.
    01-06-2015 11:55 AM
  14. grover5's Avatar
    I have the same issue. If I leave home and return it doesn't remember home as safe and requires me to use my pattern password. But once I reboot the phone then it works again.
    01-06-2015 12:06 PM
  15. Svensk Smith's Avatar
    Same issue here, my home deactivates itself in trusted places. It works one unlock and the second is locked again, If I look in trusted places home is disabled. Work place is doing fine though. I have tried pin and pattern...
    01-08-2015 05:12 AM
  16. bilalsattar24's Avatar
    have you had any luck? I'm having the same issue on GPE M8
    01-08-2015 04:50 PM
  17. menawati's Avatar
    Another thing to check.
    Wasn't working for me either - I set Home as trusted in smart lock but still had to enter my passcode.
    Then I noticed that my home address is actually at end of street on maps - I live in a weird cul-de-sac type place and google maps seems to believe my address is about 200 metres away. That is why it wasn't working (it would have actually unlocked at the end of the street if I walked there).
    So, just reset your home address to it's actual geographical location or add a new trusted place at your current loc when you are at home (I did the latter and called it 'Home Loc' or something). Worked fine then.
    01-25-2015 04:47 AM
  18. spile1's Avatar
    Smart lock does not work for me when two user accounts are set on the device as the feature can only be turned on in one account.
    Attempting to turn on Smart lock in one account results in smart lock being turned off in the other.
    02-02-2015 02:04 AM
  19. Paddy Landau's Avatar
    My experience with Smart Lock is that what you put the main account applies whichever account is currently using it.
    Maybe you should report this as a bug.
    02-02-2015 03:27 AM
  20. mark_ck's Avatar
    I had the same problem, encrypt your phone and it should show up.
    02-25-2015 01:47 AM
  21. Paddy Landau's Avatar
    That shouldn't be necessary. I had Trusted Places before I encrypted. When I encrypted the phone, although Trusted Places was still there, the encryption slowed my phone badly. I did a factory-level reset, and Trusted Places is still present.
    02-25-2015 07:37 AM
  22. barry1964's Avatar
    I've just realised that the post code for location doesn't resolve to the actual physical location of the building. I've been basing home on my post code, bur if I go onto Google maps, find my actual building and rather than trying to add home add the building as a trusted place the unlock feature seems to work just fine. It's weird cos I've never had this problem before but if it fixes it I'm not complaining, and maybe before the location was just less accurate!
    02-25-2015 06:07 PM
  23. Eternal Newbie's Avatar
    Well, this is embarrassing. I'm the topic starter, didn't get any pings that anyone had answered, so I didn't check back! Thanks for all the input.
    Security is a nightmare on this phone. I'll try the solutions suggested above. In the meantime, I can't for the life of me get any of three security options to work for me:
    - Fingerprints: I've deleted and re-entered them twice. Once or twice they've actually worked to open the phone. The other dozens of times I've tried, they don't get recognized. I angle my thumb differently, I press harder, I lift it and start over. It just. Doesn't. Work. Eventually I have to resort to my pin.
    - Trusted location: the change to the situation above is that, when I tried to enter my home address again on the other email address on the phone, I got a message that it was already entered as my home address. It seems to keep that information in common across accounts. What it doesn't mean is that it will work. It still doesn't keep the phone unlocked.
    - Password: I deliberately make my passwords intricate and difficult to guess. I finally got tired of entering it again and again and again. I've resorted now to a simple 4-digit pin. I dread what could happen if this phone falls into the wrong hands.
    So yeah - not really impressed with this so far.
    I tried downloading old, trustworthy Finger Security. The fingerprint sensor is built into the front-page graphic. Bizarrely - even though it's turned off in the settings! - the Samsung fingerprint sensor pops up on top of it! And of course it doesn't work. So I'm back to entering the pin.
    Again - I'll try the various suggestions above, and thank you. Now I'll go figure out why subscribing to this post didn't work! Maybe I'm carrying around some vexing electrical field ...
    07-20-2022 05:16 PM
  24. Laura Knotek's Avatar
    Which phone do you have, and what version of Android is it running?
    07-20-2022 05:52 PM
  25. B. Diddy's Avatar
    Wait, you're BruceWeber, who started this thread in 2014?
    mustang7757 likes this.
    07-21-2022 01:53 AM
26 12
  1. Fitness bands with Notifications?
    By dirtyjudo in forum Connected Accessories
    Last Post: 03-01-2016, 09:52 PM
  2. How can I root my Sony Xperia M : ( Model C1905 )?
    By Nuno Seven in forum Sony Xperia M2
    Last Post: 07-14-2015, 02:03 AM
  3. Fitness Bands with Notifications?
    By dirtyjudo in forum Google Nexus 5
    Last Post: 12-08-2014, 07:31 AM
  4. Why does my Samsung galaxy s4 die so quickly?
    By kingg_reyes in forum Samsung Galaxy S4
    Last Post: 11-26-2014, 01:13 AM
  5. Replies: 5
    Last Post: 11-25-2014, 06:10 PM
