How many rooted LG G3 users are out there?
anon(9029232)
164
I have recently rooted my G3 using towel root. How did you guys root and do you have any suggestions on what apps to use with root?
Duncan1982
Banned
Oct 21, 2013
1,808
Yup I first rooted with towelroot and then soft bricked, recovered by flashing firmware image, updated to v10g, I then had to use purpledrake as the rest do not work after the software update.
My Root apps are...
G3 tweakbox
Trickster Mod
Textdroider DPI
Busybox pro
Obviously you need Xposed Framework
App ops starter
Root Explorer
System app uninstaller.
I now have my G3 set just right and no further tweaks are required :)
JaiMento
179
AT&T G3
Rooted using ioroot
Just Xposed, G3 Tweaksbox, Root Explorer... (I also have a YouTube Ad blocker module for Xposed installed, but I can't remember the exact name).
Edit: Also recommend the fix for all weather animations on the lock screen.
Duncan1982
Banned
Oct 21, 2013
1,808
Is xposed framework safe? Because i was going to download but im afraid of bricking my device
Yes Xposed is Safe however just be careful of the modules you run and tweak and mess with.
Keep to the basics & you will be fine.
Don't go diving in deep, i recently did and softbricked & its just my experience that got me back up & running.
All apps above are fine but even with trickster mod be careful.
If your just after things like centre clock, circle battery, volume steps, changing status bar & toggle colours, DPI is fine but don't drop below 540dpi, I'm currently on 570dpi and it's great.
So stick to basics and your sound :)
xocomaox
2,279
Framework is safe. Modules not approved or tested for the G3 (everything but G3TweaksBox) are not safe.
I will always root because I want the most out of my phone.
FastKatt
Active member
Mar 21, 2010
31
www.BandM-Services.com
Rooted by computer, ended up soft bricked. Recovered with computer then Stump rooted. No issues since
Sent from my Nexus 7 using Tapatalk
LeoRex
Retired Moderator
Nov 21, 2012
6,223
Yes, as long as you pay attention. Be careful when loading modules for other versions of Android. A lot of people load GravityBox, but that's designed for AOSP roms, like the Nexus stuff. There are some settings specific to those roms that will cause errors if set.
The other aspect is security. Stick to modules that have a good history... Something to help clue you in that it isn't a malicious module or a keylogger, etc. Known and trusted devs on XDA, for instance.
And make a backup! 😃 A good nandroid will get you out of a lot of binds.
ffejjj
3,553
32
48
Anyone find a good version of twrp or clockwork that works on the Sprint version?
xocomaox
2,279
I'm rooted fine with Stump Root and I'm using Xposed but yea I'm afraid to do much without having a custom recovery
The bootloader has nothing to do with rooting. I believe T-Mobile is the only carrier with an unlocked bootloader. With it locked, you will not be able to use a recovery or modify the boot in any way.
danishpeer
