nokia4life
Any update does this battery really last unlike past non brand based batteries
Sent from my LG-E980 using Tapatalk 4 Beta
I've fully discharged (to 2%) the battery 3 times so far. You can expect around 8 to 9 hours of screen time with 70% brightness it seems with just under 48 hours of up time. I've noticed that the white case Is very easy to stain. Cleaning it off with a damp paper towel with a pink pattern on it resulted in the case turning a light pink. Luckily rubbing alcohol got the majority of it out. The battery also seems to report the temperature incorrectly or the sensor is in one of the cells further from the device's core as it always seems to report around 70 to 85 degrees every after repetitive benchmarking. I've also found the strange discharging and "recharging" to be getting better but it will still dip 3-4% after a few benchmarks back to back then slowly rise back up 2-3% after I turn the screen off. You can see this and the strange temperature readings on my earlier screen shots.
I've fully discharged (to 2%) the battery 3 times so far. You can expect around 8 to 9 hours with 70% brightness it seems. I've noticed that the white case Is very easy to stain. Cleaning it off with a damp paper towel with a pink pattern on it resulted in the case turning a light pink. Luckily rubbing alcohol got the majority of it out. The battery also seems to report the temperature incorrectly or the sensor is in one of the cells further from the device's core as it always seems to report around 70 to 85 degrees every after repetitive benchmarking. I've also found the strange discharging and "recharging" to be getting better but it will still dip 3-4% after a few benchmarks back to back then slowly rise back up 2-4% after I turn the screen off. You can see this and the strange temperature readings on my earlier screen shots.
I figured the adaptation would be pretty quick. I currently carry an HTC Thunderbolt with the double-capacity "pregnant" extended battery as my backup phone until the contract runs out. It's a weighty brick, but has impressive battery life, and for a Thunderbolt that's a mighty bold claim. LOL.
Well, HAD impressive battery life. After 18 months, it's lost some of its initial capacity. Still better than the stock battery, though.
I put the stock battery in it and it just felt.. wrong. Too thin to hold properly in my big hands, too light to be substantial.
What can I say? I like big phones and I cannot lie. LOL
I got it yesterday and so far so good but it messes with my battery line graph like crazy. And the time left estimate is way off.
Sent from my LG-E980 using Tapatalk 2
