ARCHIVED: [ROM] - gROM 2.2 - 10/16 - GB - With Flash - Yes, FLASH!
Status
Not open for further replies.
donbudafuko
304
4
Re: [ROM] gROM 1.0 - 9/14/11 - g Stands for Gingerbread! - ROMS U
Can u post a link to how to revertback to v9 recovery please an thanks
jcwxguy
411
84
http://forums.androidcentral.com/lg...67361-how-simplified-unroot-return-stock.html
(near the bottom on the op) *you can skip the rest of the op* -the direct links are in the op
Reference:
Manually flashing stock Recovery image (requires root)
UNZIP flash_image and stock VD recovery.img to /sdcard
$ su
# mount -o remount,rw -t yaffs2 /system /system
# cat /sdcard/flash_image > /system/bin/flash_image
# chmod 755 /system/bin/flash_image
# mount -o remount,ro -t yaffs2 /system /system
# flash_image recovery /sdcard/recovery.img
# reboot
scrosler
ROM Developer
Nov 30, 2010
1,552
954
Well I didn't see where it was posted how to get ZVH. Is there going to be a step by step instruction guide to update to ZVH baseband? I can't find it, i'm sorry if you guys get pissed at me. I really want this ROM on my phone RIGHT NOW! lol
Dude, I get it! I really do. I will post a thread on how to do the revert. Right now there are some good instructions in this post: http://forums.androidcentral.com/lg-optimus-s-rooting-roms-hacks/118973-zvh-ota-update-zip.html
Read through it then read through it again. The instructions are there but there are alot of nonsens posts to go through.
Reactions: phreak311
sfhub
2,384
741
scrosler
ROM Developer
Nov 30, 2010
1,552
954
sfhub
2,384
741
Thanks for doing that! Now that I hosed my config I am going to follow those and see how they work out for me. I will let you know.
I'll be around for another 1/2 hour or so and can assist if you run into issues. Just post on that thread and I'll respond, hopefully quickly.
strra
108
8
has anyone had any success with an OC kernel? xionia (both OG and redux) and picasticks give some pretty nasty lag and graphical issues (for me anyway)
donbudafuko
304
4
Ok got the recovery installed an now i am getting a signature abort? Not sure to do
scrosler
ROM Developer
Nov 30, 2010
1,552
954
I have not. Its prolly because those kernels are for 2.2?
sfhub
2,384
741
If you are trying to flash ZVH, then you probably have the wrong update.zip
If you have already flashed ZVH and are trying to root it, then that is an expected error.
donbudafuko
304
4
im trying to flash i did all the steps to get recovery an i downloaded the ee........update.zip renamed it to update.zip an wen i try to flash it it comes up that ill try to download from one of the other mirrors
scrosler
ROM Developer
Nov 30, 2010
1,552
954
mike9670
DROID Master
Oct 6, 2010
795
119
Hopefully it won't be long before we have a ROM that you don't have to do the V9 backwards route to get to a custom ROM
donbudafuko
304
4
Wouldn't drews gingerkernal work for this an its oc enabled an it is built off the lg source if I remember right
deadset
48
7
Using this rom and also with GingerKernel; it is working nicely so far. I can't get Wi-Fi hotspot to work although I'm sure that is normal and will be fixed soon enough. Glad to be on official gingerbread finally! :D
Edit: Haha right after I said this my phone freezes at the browser with Wi-Fi enabled and reboots. Haven't overclocked it yet. Not sure whats up.
Edit2: Frozen at Sprint now... :\ bah
Status
RandyRoyalty
