[Rom][WIP][ZVD] Slimmed CM10 Alpha 6
Status
Not open for further replies.
r0gu3dev1pr
92
15
@jonny5449
Can you add versions to your updates. Possibly update the title for the OP. It makes it easier to know when there is an update. Thanks.
Sent from my LG-LS670 using Android Central Forums
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
@jonny5449
Will do
Any1 know a mdpi cm10 ROM with a good working cm10 launcher
Sent from my LG-LS670 using Tapatalk 2
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
Please note to run this rom You MUST have an ext partition
Also dont move apps 2 SD, the script moves it for you
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
Gave it a name
Status
I made a new boot image but got boot loop so hopefully I can fix MMS next
ShadowEO
337
96
Re: [Rom][PORT][ZVD] jelly sandwich CM10
Question.. Does the microphone work? I've been using drew's CM10 for a while and my only complaint was the microphone not working (in call or Market's Voice Search). Either way, totally flashing this once the download is finished.
Edit: Well, I answered my own question :3 Tried Voice Dialer and got an initialization failure (Cannot connect to headset, although I'm trying to use the handset mic.), either way though I love this version! :3 The CM Lockscreen and Notification Bar mods are a great addition.
You did a great job porting it jonny5449
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
No but this is farther along and doesn't take up 80mb it gets moved to sd-ext must have partition to run this ROM
ShadowEO
337
96
I love it so far. Glad you ported Zakman's CM10 over :) You've got yourself a groupie for your Optimus S CM10 :3
Reactions: jonny5449
hansgroter
Active member
Jun 3, 2012
40
has anyone even tested this yet?
ShadowEO
337
96
has anyone even tested this yet? Click to view quoted image
It works pretty well, It still has the same bugs that Zakman's CM10 for Optimus V has. Also not sure if calling is affected as I don't have working cellular service on my phone (not enough money to start a sprint account) but the microphone doesn't work at all. Voice Search, Voice Dial, etc don't work. Also, migrated my sd-ext from Drew's CM10 and if you are able to get Google Now working, it's awesome :3 The only problem is that it doesn't scroll the results or cards.
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
Any suggestions on how to fix Google now??
ShadowEO
337
96
I'm not quite sure how I got it to work. Been trying to get it on my Android-x86 netbook running 4.0.4 and nothing seems to work. I've just been using the installed version on my sd-ext that magically started to work :?
jonny5449
AC Citizen
Dec 14, 2011
2,553
286
Hmmmmm that's strange ext for computer or android
ShadowEO
337
96
SD-EXT on the phone. But I've installed the same APK on the netbook and it craps out every time. The netbook version also has Intel's ARM binary translator installed as well (libhoudini.so) :)。Well.. I am using EXT4 for the root (and internal storage) of my Android installation (it co-exists with my Ubuntu 12.04 installation)
Sent from my Toshiba NB305 running Android-x86 4.0 using Android Central Forums.
Status
Sirius_A
