Does the V10 have a RGB notification LED? Single Color?
migaux
24
I currently have the HTC ONE (M8) and one of the things I didn't like is the notification led. It only has a single color so I can't assign different colors for different notifications. ALSO, it doesn't blink at all while its charging, which I hate.
I'm undecided between the LG V10 and the S6 Edge Plus. Aside from the notifications on the secondary window, does it have a multicolored notification light?
While I'm at it, anyone know if the S6 Edge Plus does?
Yea, there isn't a notification light, but you don't really need it. If you get a text, email, call, etc the icon of item stays on the second screen instead. I'm fine w/o the notification light because of that.
I don't mind the lack of led because the second screen does a decent job, but I did like how you could set custom colors for people's SMS notifications on the G4.
If the main screen is off and the second screen is real dim, do notifications brighten up the second screen when they come in?
Or do you have the light the main screen just to see them?
I don't believe it does. I just tested it. It does get brighter in certain circumstances, but I honestly don't know what triggers that. I've never really given it much thought because I see the dim display fairly well.
V10 has no LED notification light at all. Why LG would leave this off on the V10 is beyond me.
I believe the design intent was since there is an always on notification ticker that a notification LED would be redundant.
Settings > Accessibility > Hearing > Flash Alerts
Toggle it ON and it will flash the main LED with incoming calls and txt.... but thats all it does. It doesn't indicate battery charge or anything like that, and it certainly is not multi colored.
