I added wireless charging to my V20
I already have 2 wireless charging pads which I used for my retired Galaxy Note 2.
I just needed to fit a type C wireless receiver to the phone, and that's it.
I never had to plug in the USB port since that & the battery is always fully charged. Very nice.
I'm interested in purchasing one for myself, could you provide a link to where you bought yours?
These are the ones I have & I am very happy with them.
QI Receiver
Nillkin Magic Tags QI Wireless Charging Receiver Micro USB / Type C Adapter For iPhone 5S SE 6 6S 7 Plus/Samsung S6 S7 Edge
http://s.aliexpress.com/MvEjiMRv
CHOETECH Qi Wireless Charger for Samsung Galaxy S7/S7 Edge/S6/S6 Edge and All Qi-Enabled Device
http://s.aliexpress.com/ueu6VvQj
They are also available from Amazon, but as latter does not ship to my place, I brought from Aliexpress
QI Receiver
Thank you, I'll look into these options.
Hi... Are you having any problems with the receiver or does it still work fine? I am especially concerned with the phone overheating or getting damaged when charging overnight or for too long. Not sure if you have tried to charge your phone overnight and if you have run into any problems doing so. Also, is it easy to remove the connector from the port (leaving the sticker on), in case we want to charge the phone using a type c to USB cable (say when we don't have access to a wireless charger)? If you could post some pictures, would be great!
Both receiver & charger work well. I even charge my 9.7 inches tablet wirelessly.
I have on several occasions charged overnight. When it is reaches 100%, the charger goes into sleep mode with the monitor light off. Both phone & charger remain cool.
I refer to the 2 brands I mentioned earlier (Choetech & Nillkin) . I don't know about the cheaper alternatives.
For pictures open the links to these 2 products in my earlier post.
It is not difficult to disconnect the receiver from the phone's USB port, but it's quite annoying if you have to do that often. As I have power supply at my desk & a car wireless charger, I never had to charge with the bundled wired charger.
Thank you for your detailed response. I really appreciate it. Just to confirm on the products, I have links from amazon below.
Type C Receiver: https://www.amazon.com/dp/B01M11UT3...ag=hawk-future-20&ascsubtag=UUacUvbUpU5850584
Wireless Charging Pad: https://www.amazon.com/dp/B00JA7HNZ...ag=hawk-future-20&ascsubtag=UUacUvbUpU5850584
I reckon these should be good. Good to know you haven't had problems with overnight charging and that it's not that hard to remove the receiver from the USB port. I don't expect to do it often. I have one on my car too. If I get the one I listed above, plan to use it at home. I just wanted to make sure it's easy to remove the receiver from the port. Just couple more questions if I may - How long have you been using the receiver? And do you think this case would hinder with the receiver in any way - https://www.amazon.com/dp/B01N3Q29M...ag=hawk-future-20&ascsubtag=UUacUvbUpU5850584
Type C Receiver: https://www.amazon.com/dp/B01M11UT3...ag=hawk-future-20&ascsubtag=UUacUvbUpU5851006
Wireless Charging Pad: https://www.amazon.com/dp/B00JA7HNZ...ag=hawk-future-20&ascsubtag=UUacUvbUpU5851006
I reckon these should be good. Good to know you haven't had problems with overnight charging and that it's not that hard to remove the receiver from the USB port. I don't expect to do it often. I have one on my car too. If I get the one I listed above, plan to use it at home. I just wanted to make sure it's easy to remove the receiver from the port. Just couple more questions if I may - How long have you been using the receiver? And do you think this case would hinder with the receiver in any way - https://www.amazon.com/dp/B01N3Q29M...ag=hawk-future-20&ascsubtag=UUacUvbUpU5851006
Hi,
These are the products I am using.
I find you have a good deal for the charger. However, mine did not come with a power adapter.
I don't think the case will interfere with the charging. Mine is quite thick. The one I have on my tablet is thick also. My previous (brandless) charger & receiver could not charge my tablet with the same case. BTW they have already stopped working just a year after purchase.
Keep us informed about your new toys :)
I read that slow charging is better for the lifetime of the battery. It is heat in wireless charging that deteriorates the battery. My wireless charging receiver stays amazingly cool during charging, contrary to several other receivers I previously used.
Also if I have an AC source at hand, I will drop the Phone on the charging pad when not in use. So the battery level never drops too low, which is bad for it's durability.
Well, I ''read''. Don't know how true is what read.
Used to have Galaxy S6 Active with fast charge and also wireless pad. Phone did get incredibly hot while charging. 8 months later the phone battery started to crap out. Figures.
Don't have the heating problem. My V20 will get warm on wireless charging, but never hot. I have a Nillkin receiver & a 3 coils Choetech charger.
Hi there Brjik! Thanks to your suggestions, I am pretty happy with my purchases too - Nillkin receiver and the Choetech 3 coil charger. I am experiencing the same thing you are too. My phone gets warm (even tried overnight charging), but never hot. One thing that bothers me however is that it is pretty slow to charge my phone. I don't believe the V20 (or the G6 for that matter) supports fast wireless charging. Unless I am mistaken, even if I resort to getting a different fast wireless charger, it wouldn't help, would it?
On a side note, the incipio case, although fits my phone fine and charges fine wirelessly over the choetech, was too big to fit in the charger on my car. Nevertheless, this definitely works. I might resort to just having the receiver show (without a case covering the back of the phone where the receiver stays put), and live with it .
Wireless charging is slower than wired charging. It will take between 4 to 4.5 hours to fully charge the V20 from 0 to 100 %.
This does not bother me as most of the time I sit at my desk next to my wireless charger. When not in use, the phone sits on the charger and gets fully charged all the time.
A fast wireless charger will not charge the V20 faster. Last year I bought a Choetech 3 coils Fast charger in anticipation of buying a Samsung Note, but as I bought the V20 instead, I am using the charger as a normal wireless charger.
I have a Choetech T510 wireless car charger. I don't have any problem fitting my V20 (with a thick case on) into the charger.
Are you saying even a fast charger not being able to fast charge the LG V20, simply because the device doesn't support it?
Also, I ran into unexpected heating issues and the fact that last night, my phone hardly charged 40% when I left it to charge overnight! :( The first thing that comes to mind is, how did you plug the wall adapter - directly to a wall outlet or to an extension/surge protector? I plugged it in directly to a wall outlet since it was recommended in the instructions and item description. But now I am wondering if I should actually be using a surge protector instead. Let me know.
Btw, the charger I have in my car came pre-installed (Toyota Camry). It's in a weird spot, below the car audio system. It has a cap that flips open (bottom-up), and I need to place the phone inside. Turned out, with the Incipio case, I could get the phone touching the charging pad (too cramped for room). Without the case, however, fits snugly and charges just fine. I haven't really taken a long drive since I purchased the receiver (and this phone for that matter), so I am not sure how it will behave when left to charge for a long time.
In order for fast wireless charging to work on a phone it has to have the intelligence to support the function. Simply plugging in a coiled receiver does not do that. It sees it as a conventional charger. In the case of the hardwire charger the phone recognizes the fast charging brick and supports fast charging.
A fast wireless charger will only fast charge the Samsung Note & S series.
What you can try if the charge does not progress is to use the phone till the battery is completely depleted, then start charging.
If this does not work, contact Choetech.
support@choetech.com
I once contacted them, they are very helpful.
I plug the adapter directly into the mains. The adapter should be 5 V & 2 Amp. Max.
On trick I do is not to lay the charger directly on the table, but on an inverted coffee tin lid. The space between the lid & bottom of charger allows natural ventilation, hence cooling.
I just installed a wireless receiver this evening, and it sits between the outside of the back cover and inside a Ringke case. I slapped the phone down on my Qi charging pad, and it lit up immediately and started charging.
However, the phone keeps cycling a picture of fast charging, and how you're supposed to plug in the cable, etc. I cannot stop this picture from cycling on and off no matter what I do. I tried shutting off the phone, but as soon as it went down on the charger, the charger triggered the phone to start up. I can't find anything in the settings to just shut down everything during the time the phone sits on the charger. I'm very interested in knowing if anybody else encountered this problem, and how you resolved it. Many thanks. Ralph L. Seifer, Long Beach, California.
Do you mean the phone constantly turns on & off when it sits on the charging pad?
That sucks because I have the receiver and charging pad here just waiting on my phone to get here this afternoon
I don't think it actually ever turns off, just recycles the picture of how to plug in the cable charger. I have two Samsung chargers Model EP-PA510 purchased on eBay, and both work quite well with my LG G4. But when I tried the V20 on the charger on my desk, the charge went from 88% to 89%, and then didn't seem to move beyond that.
When I went to bed, I set the V20 on the charger on my nightstand, and woke up during the night to find the phone reading 100% so I guess it's OK, but the "how to charge" picture continued to cycle all that time, although I had turned off the light to keep it from disturbing my sleep.
I was encouraged, parenthetically, to find not only the phone was at 100%, but also that it was "normal" temperature, i.e., not unusually warm.
Also, I should mention here that I am not as concerned about battery life as some of the writers earlier in this post, but more focused on maintaining the operability of the USB socket, which I feel
can be driven to failure by the continuous plugging and unplugging of the charging cable. So for that reason primarily, I regard the wireless charging as essential.
Both your card & charger seem to work correctly.
I had one wireless card which kept displaying a message that the phone is on slow wireless charging each time I place the phone on the charging pad. I replaced it with a Nillkin USB C card. The problem is gone.
Try to soft reset the phone to see if the problem disappears. If no, the problem comes from the wireless card.
The main reason I like wireless charging is convenience. No need to plug & unplug and phone is always well charged.
Also, I have a backup phone and a tablet which I charge wirelessly. So I avoid plugging and unplugging 3 devices.
Prince08900
