^^ Awesome to hear because it never worked on my Rezound.
FoxFi works on my VZW X just fine.
Are you just using the one from the play store? Foxfi or pdanet? Could you post a link?
-Sent from my Droid Mini.-
I have PDanet and Foxfi. I've yet to get the wireless hotspot to work, but i have gotten the tethering to work totally fine.
Just tried it out, guess it works on my VZW unlimited Moto X. Now I have a thing in the notifications bar that says "your hotspot or wifi is active, touch here to setup" and won't swipe away.
are you on unlimited data?
Don't want my phone to report back to Verizon that I've been tethering or something stupid like that. I restarted and it went away.
Now my issue is that FoxFi had to install some sort of VPN to make the tethering work, and it made me put a pattern unlock on my phone. Now I've deleted FoxFi for now and I want to take the pattern unlock off, but that VPN stuff still won't let me go back to swipe unlock. Can't find the app or whatever to delete it now and I don't want to delete something that I need.
Settings>security>clear credentials will remove the requirement for your lock. (then you can go change/remove it.)
If that doesn't work, the app info in the Play store instructs you to delete all credentials and that will remove the PIN lock requirement.
That is removing the credentials
