Ever since I updated to Kit Kat, my calendar won't sync. No matter how many times I go into the app and select what calendars to sync, as soon as I exit the menu they all get unchecked. Anyone else having this problem?
Yep.
Mine was working, but I reset the phone and then I got hit.
I uninstalled Google Calendar and went back to the AOSP, and it's been ok.
Saw this in the reviews. Seems to be a bug with KitKat (possibly just on the X) The following worked for me, but we'll see after a reboot and/or time
Kit Kat bug If you have a problem with your calendars not being displayed, do this: uninstall Google calendar, disable calendar sync, clear stock calendar data, disable stack calendar, clear calendar STORAGE data (in settings, apps, all), reinstall Google calendar, re enable calendar sync.
No issue will my Google Calendar sync here.
Sent from my Moto X!
I'm having the same problem. After many attempts I ended up uninstalling and then reinstalling the calendar. It worked for awhile, quit again. SOMEBODY FIND A FIX THAT STICKS!!!
please.
I recommend using google calendar and disabling the stock calendar.
google calendar is build from stock calendar but with additional features and bug fixes.
