mhunter6378
Re: Exchange Services killing my battery...HELP!
This is has been reported by many users of Kit Kat that I have read about over the internet. Some users reported the problem solved with the 4.4.1 update while others report it not resolved until 4.4.2, those updates only apply to the Nexus devices while the Moto X is currently still on 4.4. There seems to be no uniformly consistent fix or workaround that I have read about and it seems to strike at random, not affecting everyone that uses Exchange. I worried about this when I got my new Moto X recently and updated to 4.4. Although, knock on wood, I have not experienced any issues so far. I rely on Exchange email for work and so far it has been working fine. I don't know if it matters but my employer is on Exchange 2010.
The email app "Touchdown" has been widely recommended as an alternative and it gets very positive reviews by users. It is reported that these sync issues caused by Kit Kat do not affect this app. It is a bit pricey ($20) though you can get a free thirty day trial to try it out. You may give that a shot in the interim and hope Motorola pushes out the more recent Kit Kat updates before the 30 day trial runs out. That's my plan if the bug hits me.
I have been having syncing issues w/ my Exchange email ever since upgrading the phone to 4.4. The account is configured to sync using Push and it only syncs the most recent 3 days of email. When I open the email program, it isn't getting the latest emails (it is a few hours behind). I then go to Settings > Corporate > Exchange account name > The calendar is up to date but the email is sitting there with the spinning wheel. If I cancel the sync then restart it a few times, it eventually successfully syncs again. It then stays up to date for a few hours then gets stuck syncing again.
I have completely removed the exchange account, cleared the cache on the "Email" AND "Exchange Services" apps then re-added the Exchange account. That helped for a few days then it started happening again. I will try that one more time but also reboot the phone before re-adding the Exchange account. If that doesn't help, then there has to be some bug in Kit Kat that is causing this behavior. The email was rock solid while on 4.2.2.
