A
AC Question
Bluetooth Audio Streaming Stops working, causes phone crashing, and battery drain...
I've got a 2013 MotoX that's on KitKat 4.4.4. I use this to stream audio to numerous Bluetooth headsets and 2 vehicles....until the past week or so.
My problem is that when I pair my phone with any of these audio receivers, I can use Google Music, or Radio streaming apps that I've used for years and they play normally... Eventually though, typically after a few seconds to a few minutes, the audio stops. In Google Music, I can often look at the app and see the time continuing to tick on the track that is playing, but can't hear anything. If I attempt to use my phone at this point, it usually locks up and stops working, forcing me to reboot it.
I noticed a few days ago that my phone, which had been plugged into a USB 1.0A charger was at 1% battery life. As soon as I unplugged it, it griped about the battery being low/dead. I checked the battery consumption chart and Bluetooth was listed as 33% of my battery consumption. How can I check my Bluetooth version number? I'm thinking something has pushed a newer version to me and has started causing these issues recently. I haven't been able to find a good guide because most posts in the past are all about pairing issues or possible issues with newer rollouts.
As a second possible fix...if someone knows of a good ROM that has native wifi-tether enabled, I'll just switch ROMs. I've got a custom apk on my phone and that's the only reason I'm locked at 4.4.4. It hasn't had any issues so I've not needed to upgrade.
Thanks.
Thanks.
